astrostart 2205a, ’04 nissan frontier
nottphireman
Posted: April 06, 2007 at 9:45 PM / IP Logged
I am in need of an install diagram for an '04 Frontier. Will I need any addtional molues or relays? It has a manual transmission.
Thanks, in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 06, 2007 at 10:13 PM / IP Logged
Do you have the manual bypass module for your astro? Part # 310-067-500
Heres a tech sheet.
Wire/Function Colour Location/Description Polarity
 12 VOLTS Green Ignition switch harness   +
 IGNITION BLACK/ white Ignition switch harness   +
 ACCESSORY RED / yellow Ignition switch harness   +
 STARTER BLACK / YELLOW Ignition switch harness   +
 KEY SENSE WHITE/ green Pin-25 on Smart Entrance Module   +
 The Smart Entrance Module is located behind the Parking brake release under the driver's side dash.
 TACH SIGNAL Black Pin-2 on ECM at back of center console   AC
 FUEL INJECTOR Opposite from Red At any injector on engine   AC
 LOCK Yellow Pin-11 on Smart Entrance Module   -
 UNLOCK Yellow/red (double pulse) Pin-10 on Smart Entrance Module   -
 DOORPIN RED / black Driver's kickpanel   -
 This is the domelight wire. Separate doorpins are GREEN/ red (driver's door), RED / black (pass. Door), RED / yellow (rear doors). All 3 wires are located at the Smart entrance module below the dash on the right side of the steering column.
 HOODPIN BLACK/ pink Pin-6 on Smart Entrance Module   -
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarm with unlock wire
 BRAKESWITCH BROWN / red At switch above brake pedal   +
 PARKLIGHTS Blue/red At light switch harness   +
 HORN Lt.GREEN/ red Pin-42 on Smart Entrance Module   -
 CLUTCH SWITCH BROWN / yellow At switch on clutch pedal bracket   TYPE 2
 HEADLIGHTS Red Pin-39 on Smart Entrance Module   -
 REVERSE LIGHTS Yellow/red In large junction plug in pass. Kickpanel   +
 DIMMER Pink/black At dimmer switch   +
 VSS WIRE Dk.GREEN/ black At right of gaz pedal (ECM)   AC
KarTuneMan
Posted: April 06, 2007 at 10:18 PM / IP Logged
You will need to use one of the 4 programable outputs programmed for start to send a (NEG)- start to the clutch wire.
nottphireman
Posted: April 07, 2007 at 1:35 PM / IP Logged
No I do not have the manual bypass module. Was not sure if I needed it. Where is a good place to get one from?
Thaks again.
KarTuneMan
Posted: April 07, 2007 at 5:05 PM / IP Logged
The same place you bought the 2205. Since you purchased it over the counter, and more than likely, from an unauthorized dealer....it has no warranty. If you got it from an authorized dealer, it still has no warranty.  So, be careful. Get the tranmission module and I would be glad to help you with any questions you might have. I love this product, and have been installing it for years. You, in my opinion, have the best on the market.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
