03 denali compustar pro battery problem
level12
Member - Posts: 13
Posted: April 23, 2007 at 10:01 AM / IP Logged
Hey Guys, I had a customer with a 03 Denali (Yukon) come in and we installed the Compustar Pro in there. Everything is working properly, but he called me a couple days back and let me know when he arms the vehicle the night before by morning the battery is dying. I told him to not arm the truck overnight and his battery was fine this morning. I know I have the relays wired properly I tested them and they are all fine, and am now wondering if this could be a BCM Issue,does it shut down on these or not, or If I have tapped into a wire that is keeping the BCM on? or can it be a bypass issue? I tested that aswell and only the 12v is showing power as it should. He lives out of town and want to save him a trip if I can. any help is greatly appreciated. thanks in advance.
Never argue with an Idiot, they will bring you down to their level and beat with you with experience.
dswift
Copper - Posts: 396
Posted: April 23, 2007 at 10:26 AM / IP Logged
If there is a GMSL2i IN there Make sure its version 1.9. There was a update on the GMSL's, Replace his module and that should solve your issue. If not test for a draw. Compustar A/S will only draw 30 milliamps.Which is not enough to kill a battery.
"dont ground out!"
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
