strange problem w/ remote starter
fchunter
Member - Posts: 8
Posted: April 28, 2007 at 8:16 PM / IP Logged
Hi guys,
I installed Prostart ct-3300 by myself. Everything was perfect for 2 weeks then suddenly car didn't start w/ remote control. Today i've checked every connection and fuses. Wires look ok but one fuse on remote starter (6-pin harness/red wire/30 A) was gone so i bought 30 A fuse and tried to replace it. As soon as i put the brand new fuse on fuse holder car started to crank by itself. Approximately 15 seconds later car started but strangely i was still hearing that car was still cranking. I have no idea what cause this.
I am not sure but could be this problem releated with remote door opener. Because fuse was ok  before i installed 2 relays for door lock/unlock + 1 relay for trunk opener.
I really need your opinions.
Thank you.
Platinum - Posts: 12,488
Posted: April 28, 2007 at 8:23 PM / IP Logged
Make, model and year of vehicle please.
fchunter
Member - Posts: 8
Posted: April 28, 2007 at 8:24 PM / IP Logged
Sorry about that.
Chey Cavalier 1994 3.1L Wagon
Thanks.
peterubers
Silver - Posts: 706
Posted: April 29, 2007 at 3:55 PM / IP Logged
Do you have a starter kill relay?
What is your tach source?
The search function is your friend.
fchunter
Member - Posts: 8
Posted: April 29, 2007 at 9:11 PM / IP Logged
Problem has been fixed.
Remote starter unit was faulty. I've replaced it and no problem so far.
Thank you for your help.
