2007 scion xb wiring
csorb
Copper - Posts: 317
Posted: June 17, 2007 at 10:38 AM / IP Logged
Can't seem to find the rs wiring info for a 2007 Scion XB. It does not seem to be the same as an 06. Any help would be greatly appreciated.
captainzab
Silver - Posts: 606
Posted: June 17, 2007 at 2:22 PM / IP Logged
i dont got the 07 either, i guess your going to have to test each wire then write them down.
or
you could try using any 07 toyota (if they did change colors for the XB, then there should be another toyota that also got the change)
Note: You Always Dont Get What You Pay For.
enice
Silver - Posts: 857
Posted: June 17, 2007 at 11:19 PM / IP Logged
Only difference I see in the 2007 according to Victory Technology is that the ign 1 is RED / black and the rest are the same for that vehicle.  Not saying that Victory is right but thats what it shows.  Just make sure that your main priority is to power up all ign wires to avoid check engine lights.
csorb
Copper - Posts: 317
Posted: June 18, 2007 at 8:52 AM / IP Logged
I made a mistake. It's an 08.
enice
Silver - Posts: 857
Posted: June 18, 2007 at 5:40 PM / IP Logged
My program shows this for the 08,
  • 12v=white(+)
  • ign=gray(+)
  • Starter=white(+)
  • ign2=white(+)
  • starter2=white(+)
  • acc=black(+)
If installation excellence is right then you MUST test all these connections with the meter.  I am assuming you know how to test the ign,acc, and starter.
