2006 saturn add on keyless entry
bassmanxxx
Posted: July 14, 2007 at 9:36 PM / IP Logged
Just installed a KE-30 keyless entry system on my 2006 Saturn ION.Everything works fine except every time the brake pedal is applied, the doors lock or unlock.Would a diode in the trigger line solve this problem?
bassman
KarTuneMan
Platinum - Posts: 7,056
Posted: July 15, 2007 at 5:02 PM / IP Logged
Why did you tie into the brakes for a keyless entry? Or did you?
bassmanxxx
Posted: July 15, 2007 at 6:07 PM / IP Logged
No I didn't tie into the brakes, that's what makes this so weird.Apparently, the voltage drop used by the brake lights is keying the door lock circuit.That's why I was asking if diodes would help and where to place them in the circuit.
bassman
