06 ram door trigger
gtchida
Copper - Posts: 89
Posted: July 22, 2007 at 11:46 PM / IP Logged
Just about completed an install on 564T in 2006 Dodge Ram 2500 and I am having trouble locating the large gray plug at the cluster for the door triggers as stated in the wiring diagram. I have found the driver door in the driver kick but I want to avoid going to each kick - does anyone have a tip on this?
Thanks,
Gary
Platinum - Posts: 12,488
Posted: July 23, 2007 at 9:50 AM / IP Logged
Did you remove the instrument cluster from the dash ? It's the only gray plug on the back of the cluster
gtchida
Copper - Posts: 89
Posted: July 23, 2007 at 7:21 PM / IP Logged
No, is it easy to remove? How do I remove it?
Gary
Posted: July 23, 2007 at 11:13 PM / IP Logged
Remove the cluster bezel from the instrument panel.
Remove the four screws (3) that secure the instrument cluster (2) to the instrument panel structural support (4).
Pull the instrument cluster rearward far enough to access and disconnect the three instrument panel wire harness connectors (1) from the connector receptacles on the back of the cluster housing.
Remove the instrument cluster from the instrument panel.
gtchida
Copper - Posts: 89
Posted: July 23, 2007 at 11:32 PM / IP Logged
Many thanks, Jeff
Gary
swerks
Copper - Posts: 224
Posted: July 30, 2007 at 4:25 PM / IP Logged
use a data module onthese it greatly reduces installation time the xk 532 provides doorlock security bypass and output for alarm also doess transponder.
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
