Directstart reviews, Accord wiring
alkali
Posted: February 16, 2003 at 12:45 AM / IP Logged
Hi all
Two questions here.
1. Anybody has experience with Directstart cs124 (from www.12voltshop.com). I'm planning on this module and I have seen couple problem with the 423 they're selling, I think velocity motor can help me on this.. ;) )
I'm locate in Toronto, ON, anybody know a cheaper place I can pick this up then 12voltshop? they're selling CAD120 + 25 for the bypass module for 2002 Accord.
2. Now down to the wiring diagram from this site for the 2002 honda accord. it listed as following:
Starter- Cut after Fuse Panel, not at Ignition Switch. (what does this mean? If i'm installing a starter, do I HAVE to connect it after the fuse panel? or I can disregard this comment and do it normally at the ignition harness?)
Ignition 3 - Power this or ABS Light on Remote Starter. (?? is this just the second ignition wire? what exactly does the comment means?)
Tach - Distributor, anyone know where this wire is under the panel? just trying to avoid running another wire from the engine compartment).
Seems like this is a really hard job according to the following link. :) Maybe I should take a trip to a mitchell-on-demand terminal.
Original page: https://www.the12volt.com/installbay/detail.asp?info=alarm&year=2000&make=Honda&model=Accord&ID=17963&type=Alarm
Thanks for any input.. this is a great place.. :)
Evan
yalkali@yahoo.com
pecas
Member - Posts: 7
Posted: March 12, 2003 at 9:02 PM / IP Logged
i have the wiring diagram of honda civic i dont know if as the same of honda accord .
amende_padilla@hotmail.com
2vmodular
Member - Posts: 46
Posted: March 12, 2003 at 10:17 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|BLACK/ white *1      |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
| SECOND IGNITION|yellow              |+ |ignition harness            |
|        ACCESSORY|WHITE/ black        |+ |ignition harness            |
|       POWER LOCK|BLACK/ blue *2       |- |passengers fuse box *3      |
|     POWER UNLOCK|orange              |- |passengers fuse box *3      |
|       LOCK MOTOR|WHITE/ red           |   |drivers fuse box            |
|     UNLOCK MOTOR|*4                  |   |drivers fuse box            |
|    DISARM DEFEAT|lt. GREEN/ red       |   |*5                          |
| PARKING LIGHTS +|RED / black           |   |drivers fuse box            |
| PARKING LIGHTS -|RED / yellow *6       |   |steering column             |
|       HEADLIGHTS|blue/red            |- |steering column             |
|     DOOR TRIGGER|BLACK/ white        |- |passenger fuse box *7       |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|orange              |- |drivers kick panel *8       |
|        HOOD PIN|yellow/red or yellow|- |hood pin switch or *13      |
|TRNK/HTCH RELEASE|WHITE/ red           |+ |drivers kick panel          |
| FCTRY ALARM ARM|*9                  |   |                            |
|FCTRY ALRM DISARM|*9                  |   |                            |
| DISARM NO UNLOCK|blue               |- |*10                         |
|       TACHOMETER|blue               |   |tach test connector *11     |
|      SPEED SENSE|blue/white          |   |*12                         |
|       BRAKE WIRE|WHITE/ black        |+ |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ blue      |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|RED / yel - RED / blu   |A |drivers door switch        |
| RF WINDOW UP/DN|blu/wht - blu/yel   |A |RF window switch            |
| LR WINDOW UP/DN|RED / yel - RED / blu   |A |LR window switch            |
| RR WINDOW UP/DN|RED / yel - RED / blu   |A |RR window switch            |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when
adding remote start. Use DEI part number 555H or 555U. *1 Must interrupt
the wire between the keyswitch and the fusebox, not between the fusebox and
the starter, to keep the check engine light from coming on.    *2 Use
BLACK/ white for lock and GREEN/ red for unlock on LX models without factory
security. These wires are located in a two pin gray connector by the front
of the drivers side fuse box. *3 in a green 20 pin connector. *4 yellow on
the EX and lt. GREEN/ red on the LX *5 located in the same plug as the door
lock wires. Also found in a 14 pin green plug at the drivers fuse box on the
EX model.   *6 Only available on the EX model. *7 In a green 4 pin
connector. *8 Above the hood release in a gray 18 pin connector. On the DX
& LX models, also found in a 2 pin connector behind the drivers fuse box. *9
Arms and disarms with the door locks on the EX models. The LX models arm
only with the factory transmitter.    *10 On the EX the wire is located at
the drivers power window switch, on the LX the wire is at the
keyless/security unit which is attached to the drivers underdash panel.   *11
The tach test connector is located behind the battery on the 4 cylinder, and
on a bracket attached to the drivers side strut tower on the 6 cylinder
motor. The tach test connector is a white 2 pin connector, and may be
covered by a black rubber boot. *12 Located at the first plug on the ECM, it
is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet
on the passenger side of the center console. There are 4 plugs total. *13
On the EX models it is in a green plug next to the passenger side fuse box.
On the LX models it is at the keyless/security unit, if equipped, which is
attached to the driver side underdash panel.
jrilla
Gold - Posts: 1,498
Posted: March 12, 2003 at 10:21 PM / IP Logged
I am curious what problems you have seen with the 423?
J Rilla
Owner/Installer
