compustar into lexus sc
menappi
Member - Posts: 25
Posted: July 26, 2007 at 5:23 PM / IP Logged
Hey all, I need a little help installing my compustar alarm into my 93 sc300. I have attached a picture of the wiring diagram for the alarm and the vehicle wiring diagram. Not sure exactly which wires go where, I have done two other alarm installs but they were in my honda and the viper diagram seemed a lot easier to understand. If someone could maybe draw lines on my image to where i connect each wire that'd be great!
compustar into lexus sc -- posted image.
peterubers
Silver - Posts: 706
Posted: July 26, 2007 at 5:54 PM / IP Logged
CN1-3 = White
CN1-4 = chassis ground
CN1-1 = red wire of siren (black wire of siren = chassis ground
CN1-2 =  not connected
CN2-1 = GREEN/ blue (-) at steering column harness (not listed in your diagram)
CN2-2 = GREEN/ red (-) at steering column harness
CN2-6 = BLACK / YELLOW
CN2-9 = green(-)
CN3-2 = RED / white(-)
CN3-3 = RED / white(-)
CN4-2 = need to use relay as follows (BLACK/ silver dots lexus wire)
---> 85: CN4-2 wire
---> 86: 12 fused volts
---> 30: 12 fused volts (10 amp fuse)
---> 87: BLACK/ silver dots wire of lexus (+)
CN4-4 = GREEN/ blue (-)
CN4-5 = RED / black (-)
If you want to use the CN3-1 hood pin sensing wire, you'll have to purchase an aftermarket hood pin and connect it to this wire.
CN2-5 (starter kill) will have to be used with a relay again, and you'll have to split the starter wire (BLACK/ white) in two:
85: CN2-5
86: 12 fused volts
30: key side of BLACK/ white wire
87a: motor side of BLACK/ white wire
87: nothing
hope this helps, best of luck -- it's a real straightforward install
The search function is your friend.
dswift
Copper - Posts: 396
Posted: July 26, 2007 at 6:04 PM / IP Logged
deng.... hahah For future reference the my man who posted this. The wiring diagrams are used for a reference only. Always test before you start connecting things. Word
"dont ground out!"
menappi
Member - Posts: 25
Posted: July 29, 2007 at 7:03 PM / IP Logged
Hey thanks a lot. for the 'trunk output' where you say I would need a relay, I don't need that option do I? I'd rather just leave off a remote trunk pop. And with the starter kill, I can use the relay that came with the alarm right? It's alreayd attached to the harness. Also how did you know the wires for the parking lights and horn output if the wires aren't on the diagram?
P.S.-any idea how to get my siren wire through the firewall. I found a hole on the passanger side but can't get it to come through.. :(
menappi
Member - Posts: 25
Posted: July 31, 2007 at 10:37 PM / IP Logged
Bump, having some trouble (sorry ultimate noob, but I want to learn). Factory disarm wire, says it's green in the 'kick panel', but man there are like a hundred wires in the 'kick panel', a huge mess of harnesses. Anyone have any more specifics? How does one test these wires to make sure they are right, for instance, the factory disarm, or the door unlock lock, like if there was more then one color (does that happen?)
menappi
Member - Posts: 25
Posted: August 01, 2007 at 2:27 PM / IP Logged
Sorry another Question about the factory disarm, when/if I find it, do I CUT IT and hook it up to the wire from the brain, or do i splice the wire from the brain into it?
enice
Silver - Posts: 857
Posted: August 01, 2007 at 2:49 PM / IP Logged
This is where a multimeter is an installers best friend.  To test the factory disarm you would have to connect your red test lead to that wire, black lead to ground and have it on DC settings. Turn the key cylinder.  Your meter will show a read everytime you turn the key in the door cylinder.  It could go from a voltage between 7-12 and drop down to 0v when the key is turned in the door cylinder to unlock.
menappi
Member - Posts: 25
Posted: August 01, 2007 at 3:00 PM / IP Logged
So when I find the right wire, do I cut it and hook it to the 'disarm output' on the alarm, or splice the wires? while it's still hooked to the harness?
enice
Silver - Posts: 857
Posted: August 01, 2007 at 3:22 PM / IP Logged
tap into it. do not cut
menappi
Member - Posts: 25
Posted: August 02, 2007 at 11:06 PM / IP Logged
Thanks, ok I wired up everything EXCEPT-
factory disarm (green wire in kick panel)-Have no clue where it is, there are a gillion green wires, anyone know which plug it's in????
HORN/Parking lights (steering column harness?) - Can't find these wires
door trigger (RED / white) - Found TWO red white, one goes into the door the other doesn't but I'm not sure which one it is, i don't want to hook it up wrong and later come back. Also don't know how to test.
Now it seems that my interior lights don't work at all, after pulling plugs and all this...any help?
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
