99 lexus rx300, alarm/autostart
desh187
Copper - Posts: 310
Posted: August 24, 2007 at 12:48 AM / IP Logged
Hi,
Has anyone installed an alarm/autostart on a 99 Lexus RX300 suv.Is it a lot more work and I need to know a little bit more about the door locks and if anything special has to be done for hvac system.I have seen the vehicle wiring info on this site but it is missing the notes.
peterubers
Silver - Posts: 706
Posted: August 24, 2007 at 2:26 AM / IP Logged
12 VOLT CONSTANT  WHITE/ BLUE (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
 IGNITION 2 BLACK (+) IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 PINK (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE BLUE with SILVER Dots (-)  IGNITION SWITCH HARNESS
 PARKING LIGHTS ( - ) GREEN/ RED (-)  @ STEERING COLUMN HARNESS
 PARKING LIGHTS ( + ) GREEN (+)  IN DRIVERS KICK PANEL, GRAY 15-PIN PLUG
 POWER LOCK See NOTE *1  See DIAGRAM   14301_RX300_TOYOTA and LEXUS door lock interface.pdf
 POWER UNLOCK See NOTE *1  See DIAGRAM
 LOCK MOTOR WIRE N/A
 DOOR TRIGGER RED / WHITE (-) See NOTE *2  @ STEERING COLUMN HARNESS
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN WHITE/ RED (-)  @ STEERING COLUMN HARNESS
 TACH ORANGE  IN 10-PIN PLUG, RIGHT OF FUSEBOX
 WAIT TO START LIGHT N/A
 BRAKE GREEN / WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  Disarms with KEYSENSE Wire  @ IGNITION SWITCH HARNESS
 ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY  TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
 NOTE *1 THIS VEHICLE'S DOORLOCKS ARE SPECIAL AND WILL REQUIRE AN EXTRA RELAY, PART #775 AND 2 DIODES, TO CONNECT, See DIAGRAM
NOTE *2 THIS DOOR TRIGGER WIRE GOES TO THE KEY CYLINDER ILLUMINATION RING AND READS THE DELAY.
The search function is your friend.
peterubers
Silver - Posts: 706
Posted: August 24, 2007 at 2:27 AM / IP Logged
peterubers
Silver - Posts: 706
Posted: August 24, 2007 at 2:28 AM / IP Logged
HVAC is straightforward -- one accessory wire that needs 12 volts.
