compustar p2w900fmas vs viper 5900
edan
Member - Posts: 14
Posted: September 09, 2007 at 5:49 PM / IP Logged
I realize there are some topics already about this subject, but I have some more specific requirements, plus most of those posts were pretty old.
So I just bought a 2007 RAV4 Sport (V6/4WD), and want to install a remote starter/security system. I am definitely letting a professional do this, for the obvious reasons, but I have some doubts, and I hope you guys can help me figure this out.
Features I want: Radar/Motion sensor (and want to be able to tell from the remote if it was motion that set off the alarm, or the shock sensor), Extra LCD keyfob, Defroster control and optionally window/sunroof control.
I have 2 dealers I am considering. 1 of them has been in business for a long time, and recommends the CompuStar system. He says (and showed me the remote) that he uses this system himself, and that if the Viper was that much better, he would be selling it. His shop focuses on audio and this kind of work, so that's a good sign, but he couldn't really tell me why the CS was better than the Viper. Another thing that concerned me is that he told me that he just did a few RAV4's, but yet was convinced that every Toyota requires the security module that deals with those passive anti-theft keys. As far as I know, only the Limited edition has this option, so either he is getting his cars mixed up, or his work is accurate. He did say he won't install it if it isn't needed, but it does make me wonder.
I also asked him about a tilt sensor (in case my vehicle gets towed, or someone is jacking it up to steal the wheels), and he said that almost every sensor out there to help prevent wheel theft is useless, and doesn't recommend tilt sensors in general.
I also located another dealer, which sells the Viper systems (I think they could order anything tho). The guy I talked to does sound like he knows what he is talking about, but the business also does other car maintenance work, so not sure if they have a lot of experience with installing advanced alarm /remote start systems. Another concern I had is that they won't install the starter kill feature. They insisted that it does more harm than good. Should this be a showstopper, especially since my car doesn't have the passive anti-theft system (rfid chip in keys)?
Some of the other things that I am worried about is the keyfob. Which one do you guys think is better. The Viper or the CS? I live 30 minutes north of Syracuse, so obviously cold temps are a major concern to me. It looks like range is 3000ft for the CS, vs 1mile for the 5900 series.
I am hoping that some of you have hands experience with both systems, and can recommend which way to go. If there are better choices out there, don't hesitate to mention them either. Thanks guys!
edan
Member - Posts: 14
Posted: October 01, 2007 at 7:43 PM / IP Logged
So I decided to go for the Compustar model, but the installer ran into an issue. They can't figure out (based on info from the manufacture) how to hook up the rear defroster. They are willing to figure it out themselves, but I figured I would check here to see if anyone knows the answer. I have a 2007 Toyota RAV4 Sport (V6/4WD) with manual climate controls. Thanks!
Posted: October 02, 2007 at 1:29 PM / IP Logged
I have 2 issues here.
1) In Europe every Car sold since Jan '97 has had to have a factory transponder fitted.
2) If you can't feed the heater defroster circuit via a second ignition, you can go to the relay. (I was doing this 10years ago on Maximas.
Every good manufacturer eg compustar or DEI knows about this, I'm suspicious that your installer hasn't approached them or a Toyota dealer for advice.
dswift
Copper - Posts: 396
Posted: October 02, 2007 at 6:13 PM / IP Logged
What he said. Another way you can tell. Upon purchase of the vehicle you receive 3 keys. Two dark gray(looks black) and one light gray (valet key). Transponders....
"dont ground out!"
edan
Member - Posts: 14
Posted: October 02, 2007 at 7:13 PM / IP Logged
Well I definitely don't have the transponder, it's optional now starting with the 2008 Sport models, they confirmed this.
They contacted Compustar, but the information they got wasn't helpful. This place has been in business since 1976, and has had good references, so I am hoping they know what they are doing, and are just being really cautious.
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
