old school alarms
usabuilt
Copper - Posts: 161
Posted: September 11, 2007 at 12:29 PM / IP Logged
Any of you guys ever do an alarm with a key in the fender? Back then a "high tech" alarm was a passive system that shut off when you turned the ignition key to the on position..
I miss those days, when the customer came and asked you a question and trusted your response.
Also no T-taps, not butt connectors and no soldering..just tape it up and collect your $500.00..
Posted: September 11, 2007 at 5:15 PM / IP Logged
And in the UK ours had pendulums which triggered off every time a truck went within 100 yards but the villains could jump all over it and still not trigger?old school alarms -- posted image.
Mind you one of those long gone manufacturers made an adjustable plastic pin switch that still 30yrs on hasn't been bettered even by Harrison.
Mike M2
Platinum - Posts: 2,652
Posted: September 12, 2007 at 6:22 AM / IP Logged
Yep, i did hundreds of them. The big trick was to keep the keyswitch far enough away from a light or something that you couldn't just unscrew it and cut the wires. Most were a big siren that looked like something off a 50's ambulance.
Mike M2
Tech Manager
CS Dealer Services
KPierson
Platinum - Posts: 3,527
Posted: September 12, 2007 at 10:50 AM / IP Logged
Wow, I thought this thread was going to be about Viper 300HFs.
Those are 'old school' to me!   :)
Kevin Pierson
Posted: September 13, 2007 at 12:00 PM / IP Logged
Come-on KP I when I was a youngster, the dead sea was merely il!
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
