96 Saturn SC2 - GM alarm - not arm/disarm
ccworks2000
Posted: February 18, 2003 at 5:45 PM / IP Logged
96 Saturn-GM alarm - box says Carbine CA-200 (I think this is the alarm box, fuses okay) - just found out have alarm when reset computer by removing neg. cable on battery....(siren went off) - remote model ABD15DST - Remote will unlock doors/lock doors/trunk release - panic button is not working and no alarm chirps or siren - WHAT DO I DO NOW????
jgoodman
Posted: March 31, 2003 at 9:06 PM / IP Logged
I have had the same prob with my 98 SC2. Try this link:
http://www.asianwolf.com/rsguide.pdf
You may have a different alarm system but the concept should be the same. They use relays to allow an aftermarket alarm to work with the factory alarm. This does work, the cutting of the pink wire and grounding the yellow/black did not work for me.
Good luck
