98 astro phonics digital remote start
big pip
Member - Posts: 12
Posted: September 16, 2007 at 8:37 PM / IP Logged
Just installed this and I hot a classic case of the 'starts, but shuts right off' and I am begining understad the whole PassLock II thing now and I have seen there are a few out there  but reading the installation manual to my alarm it seems like it is already installed.
There is a blue/white wire : (-)200mA Bypass Output When Remote Start
and there is a yellowwire: (+)Ignition of Key Cylinder (Key On) Input.
Are these the two wires that are needed to bypass the passlock system?
eric-tech
Member - Posts: 20
Posted: September 17, 2007 at 8:48 AM / IP Logged
What's your vehicle?  You need only the bypass (-) wirre, this will send out ground when you remote start the car.
Take your time, a solution is just around the corner :-)
big pip
Member - Posts: 12
Posted: September 17, 2007 at 9:14 AM / IP Logged
It is in a 98 Chevy Astro, what do I hook up the bypass (-) to?
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
