enable door locks via key fob on mazda3
hwilliams59
Member - Posts: 11
Posted: September 24, 2007 at 3:28 AM / IP Logged
I have an 08 Mazda3 MS3. I want to add a turbo timer and keep the factory alarm system if possible. I would only need to be able to arm the alarm or atleast lock the doors with the key fob while the car is running. Installing the turbo timer is cake but I would like to have it work with the factory alarm.
I know I can simply manually lock the door once getting out of the vehicle. Or even arming it after it shuts down with the keyfob. But would be nice to do it this way.
kola7126
Copper - Posts: 93
Posted: September 24, 2007 at 7:28 AM / IP Logged
Try to close the car from the second keyfob  when the car is running. If it will be closed-turbotimer it is possible to connect.
hwilliams59
Member - Posts: 11
Posted: September 24, 2007 at 2:24 PM / IP Logged
I know it is possible to connect the TT but the key fobs will not lock the door/arm the alarm while the car is running.
Friday, November 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
