nissan altima driver lock problem
alariskirein
Member - Posts: 15
Posted: October 04, 2007 at 12:08 PM / IP Logged
hi there. i just made an install on a 98 altima and everything works just fine .but the auto rearm every time i close the last door only works the first time after i removed the key from the ignition sw. and then i reopened the  door and dont start the countdown to the rearm. the alarms is a  k-9 mundial ss. i fix that making a jumper from the key sens wire to + and now works every time. after  2 weeks the customer brings the car back with a problem in the door locks the driver lock works sometimes .the other 3 door locks works fine but they make a noise like theres a feedback on the power. and the sw in the driver door does the same open and close all the other doors. could be the driver door motor?i'm going to try disconecting the dl wires from the alarm and see what happens. any help will be appreciated. please somebody help!!! by the way i also send a pulse from the dl negative to the factory alarm disarm .cause i dont want the customer to come back due to the factory alarm going off and he doesn't have the remote for the factory alarm. thanks in advance
alariskirein
Member - Posts: 15
Posted: October 04, 2007 at 3:36 PM / IP Logged
UPDATE:  i just check the car and removed all the conncetors from the alarm and test the dl with the door sw and they work ,but i notice that after pressing the sw several times the locks lose power and start making noise and the driver don't operate either way. now i replace the alarm brain with a new one and the same thing happens. i think there's a problem with the factory relays built in the smart entry module.any  comments?? the customer ask me to remove the alarm and install another brand to see if this fix the problem ,and of course i think ( what the f... is he thinking) we all know that any alarm is going to do the same thing. well he blame  me that the alarm could damage the smart entry module .how can i explain so the customer with a tiny brain  understand that electrical components fail without  previous notice.   i told him to take the car to another alarm shop so i hope a brother tell him that everything is ok and he let me live in peace . amen
alariskirein
Member - Posts: 15
Posted: October 04, 2007 at 3:42 PM / IP Logged
Sorry i forgot   the car is a 98 altima 4 door
alariskirein
Member - Posts: 15
Posted: October 26, 2007 at 2:14 PM / IP Logged
i just removed the k-9 mundial ss alarm ,and instead i install an auto page alarm and seems to work fine the customer says it worked fine now. so i guess the k-9 is not very compatible with nissans.lol .
