1991 honda civic lx
accessdenied
Copper - Posts: 69
Posted: October 29, 2007 at 4:48 PM / IP Logged
Hi all,
Anyone have the wiring diagram?
Thanks!!
kola7126
Copper - Posts: 93
Posted: October 29, 2007 at 4:54 PM / IP Logged
  HONDA
 MODEL YEAR(S)
 CIVIC  1988 -1991
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  WHITE/ BLACK (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 BLUE/WHITE (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) RED / GREEN (+)  @ STEERING COLUMN HARNESS
 POWER LOCK GREEN / WHITE (TYPE B)  IN DRIVERS KICK PANEL
 POWER UNLOCK GREEN/ RED (TYPE B)  IN DRIVERS KICK PANEL
 DOOR TRIGGER GREEN/ RED (-)  LOW IN DRIVERS KICK PANEL
 DOMELIGHT SUPERVISION USE DOOR TRIGGER
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLUE/RED (-)  @ STEERING COLUMN HARNESS
 TACH BLUE  @ DISTRIBUTOR
 WAIT TO START LIGHT N/A
 BRAKE GREEN / WHITE (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT N/A
accessdenied
Copper - Posts: 69
Posted: November 18, 2007 at 11:23 AM / IP Logged
Thanks kola7126 for the info.
I know this is a Direct Wire diagram, does anyone can provide the DEI diagram to compare?
I am having a hard time finding the power door locks wires based on diagrams above location.
I removed the kick panel where the hood release lever is attached and there are no wires behind it I can see.
Also, this is where the door trigger is said to be. So no dice on that wire either.
I know various manufacturers have different or maybe more detailed locations where to get a wire in addition to alternate wiring connections.
Can anyone assist?
KarTuneMan
Platinum - Posts: 7,056
Posted: November 18, 2007 at 3:58 PM / IP Logged
Look up in the kick, you will see a plug clipped to a pretty good sized tube of body metal.
It's really more under the dash than in the kick.
accessdenied
Copper - Posts: 69
Posted: November 20, 2007 at 4:38 PM / IP Logged
KarTuneMan, are you referring to pin-type connector clipped to a roll-cage/tube type metal body support?
Thanks.
KarTuneMan
Posted: November 20, 2007 at 4:44 PM / IP Logged
NO.....please accept my appology. The locks are IN THE DOOR at the keyless module
I was thinking (not thinking at all really) of a diif. year.....
Man I'm sorry.1991 honda civic lx -- posted image.According to the astrochart.
AIlthough I have seen a picture of this plug I spoke of.....LOOK FOR IT, if it's not there.....then call me an idiot.
And again sorry for the potentially miss information. (God I hate that)
accessdenied
Copper - Posts: 69
Posted: November 20, 2007 at 4:47 PM / IP Logged
This might be a long shot, but do you recall the number of pins this connector has?
accessdenied
Copper - Posts: 69
Posted: November 21, 2007 at 12:29 PM / IP Logged
KarTuneMan, no apologies needed. You are helping more than you think..
Curious though, the Directwire diagram above say it's in the Driver Kick Panel and you say the wires in the door itself..
So this goes back to what I said previously to various manufacturers have different or maybe more detailed locations where to get a wire in addition to alternate wiring connections.
Man, can you provide me the diagram you use for this 91 civic lx?
Thanks!
KarTuneMan
Posted: November 21, 2007 at 9:08 PM / IP Logged
If one says "in the door" and another says "in the kick panel" Look in the boot that goes from the door into the kick!
