2002 ford winstar
nowires
Member - Posts: 9
Posted: February 21, 2003 at 9:32 AM / IP Logged
I've installed an audiovox aps685 with a DEI fff5 in a 2002 winstar. I've programmed the 555f and it started, but no matter where a place the transponder It won't start - any suggestions on location?
Platinum - Posts: 12,488
Posted: February 21, 2003 at 9:42 AM / IP Logged
My notes tell me that the 555F doesn' t work on the 2002 Windstar's, only the 555U ? Tis could be the problem, but I not for sure.
nowires
Member - Posts: 9
Posted: February 21, 2003 at 9:50 AM / IP Logged
What about the ford part I've seen listed here? ANy feedback
Posted: February 21, 2003 at 10:15 AM / IP Logged
Might just be a Ford universal bypass module. You will need a key in the module to induce the PATS code to the PATS computer. Check it out at your local dealership and ask them if it is a keyless or a key required bypass for the 2002 Ford  Windstar ?
Bnluis
Silver - Posts: 578
Posted: February 22, 2003 at 9:54 PM / IP Logged
If the car key has a  Blue FORD logo on it it will require a coded to bypass the module. The 555f won't work.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
