93 firebird
Cachas22
Posted: February 21, 2003 at 7:33 PM / IP Logged
93 firebird
Door LockLight Blue Driver's Kick Panel Reverse Polarity
Door UnlockDark Blue Passenger's Switch is Master Switch
above posted in forum
since passenger switch is master switch, can't i just do both connections in the passenger switch panel?  i only ask because i had my car apart last week and could not find the light blue wire in the kick panel - oh by the way these are postive trigger locks so i have my relays wired already or am i wrong about these being positive trigger locks?  i've got all the basics wired already (lights, door trigger, starter kill) just need the door lock and unlock to finish installation.  alarm - crimestopper cs-2011rs II
thanks for any info
mobiletoys2002
Gold - Posts: 1,050
Posted: February 21, 2003 at 9:00 PM / IP Logged
you can wire them from eithe rdoor harness but make sure the switch side wires are facing the master switch or it will not work. once you cut one of the suspect wires then check door locks from both switches the switch that loses all operation is the master switch, that is the switch side for both wires. these locks are suposed to be 5 wire reversed polarity door locks which will show positive on lock or unlock but rest at ground which means you need 2 relays to interface corectly.llok in the forum diagrams for reversed door lock wiring and follow directions.MAKE SURE YOU HAVE A 5 WIRE AND NOT A POSITIVE PULSE BEFORE MAKING CONECTIONS THESE TEST VERY CLOSE TO EACH OTHER AND YOU MUST KNOW FOR SURE OR YOU MAY BURN THE SWITCH.
