ch tbu.2 on a 07 dodge nitro
mrjc480
Member - Posts: 44
Posted: November 06, 2007 at 10:17 PM / IP Logged
If I use this interface do I still need to run a relay and resistor to the Mux/starter wire or is it built into the module?  Will I still need to run the +starter wire from the module?  What exactly is the acc circuit used for?  The a/c is on the ign circuit so I dont beleive that I should power this up.  Also If I used a SL-CAN, would that have saved me from having to grab each door trigger, lock, parking lights, tach and ect?  Heres the manual http://www.autoland.ca/sharedVSite/common/showPart/showPartNumberGuides.asp?partNumberID=9691&distid=14#
Im moving to MEXICO and Im not speaking spanish!
Twelvoltz
Platinum - Posts: 2,384
Posted: November 07, 2007 at 7:29 AM / IP Logged
It is built in, no need to add extra resistors/relays.
Yes but in the 07 Nitro you do not need to hook up the starter + out from your remote start to the vehicle, just to the module.
To power your A/C and Heat. This is handled by that MUX wire in your car.
According to this you will still have to interface the parking lights but everything else is handled by the CAN-SL2.
