cavalier remote starter problem
ericdenis12
Member - Posts: 6
Posted: November 11, 2007 at 7:32 PM / IP Logged
Hi i recently installed a remote star system in my 2002 chevy cavalier, the problem is the car starts for 5 sec. then turns off it then starts again and turns off. what could be the problem?? Im thinking its somthing to do with the tach wire, i connected it to the PURPLE / white wire comming out of the PCM. Anyone know how to correct this?
moonliter
Copper - Posts: 322
Posted: November 11, 2007 at 7:48 PM / IP Logged
This car has passlock2. what kind of rs & bypass module you installed in it ?
ericdenis12
Member - Posts: 6
Posted: November 11, 2007 at 7:54 PM / IP Logged
the pass lock has been bypassed succefully with the 555L or somthing like that
moonliter
Copper - Posts: 322
Posted: November 11, 2007 at 8:14 PM / IP Logged
you didn't answer my other question. What make & model is your remote starter ? Anyhow, try relearn the tach.
ericdenis12
Member - Posts: 6
Posted: November 11, 2007 at 8:34 PM / IP Logged
oh sorry about that the rs is a automate its also been called a radiostar with no specific model ....its more of a after market system or no name system....., how do i relearn the tach??
thanks
moonliter
Copper - Posts: 322
Posted: November 11, 2007 at 8:48 PM / IP Logged
I have no info on this. Im afraid i can't help you. Don't you have an install manual ? it should show u how to do that.
lspker
Silver - Posts: 503
Posted: November 11, 2007 at 8:55 PM / IP Logged
Radiostar have problems with remote starting, expecially in the cold.  Sold through surplus store I believe.
Sit in the car and try to remote start.  Watch the car security light, if stays on or flashes tou bypass is not working.
ericdenis12
Member - Posts: 6
Posted: November 11, 2007 at 8:58 PM / IP Logged
the secuirity is bypassed successfully and the car starts but for some reason shuts down and restarts again. I think the starter does not know the car is started and think its a failed attempt so retries.
Chris Luongo
Platinum - Posts: 3,746
Posted: November 11, 2007 at 10:16 PM / IP Logged
Try temporarily reprogramming your unit for voltage sense mode.
If it works in voltage sense, then you have the wrong tach wire, or the tach rate wasn't programmed right.
The unit may work perfectly forever in voltage sense, or it's possible that when it gets really cold out, it won't work very well...........you could always just leave it on voltage sense for a while, and see how it goes.
On the other hand, if you have the same problem even when using voltage sense, it must be something else.
ericdenis12
Member - Posts: 6
Posted: November 11, 2007 at 10:38 PM / IP Logged
ok for this methode were do i hook up thewire?? and i have a wire that says it should be hooked up to the oil sensor light or altenator is this the wire i use? Thanks
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
