sherlock d900t alarm/auto start problem
desh187
Copper - Posts: 310
Posted: November 13, 2007 at 8:57 PM / IP Logged
Got a 2005 Honda Odyssey with a sherlock alarm/auto start.Never seen this system before and the problem was that alarm/auto start works but the keyless entry does not only thru remote.It has a Da900 little module which i dont now what that is and it has a separate pkh3 transponer bypass and another module which has to be for the door locks(this module says bypass kit on it but the model number has peeled off)
Is anyone familiar with this and any feed back will be very much appreciated.Thanks
jacqueslacombe
Copper - Posts: 124
Posted: November 13, 2007 at 11:09 PM / IP Logged
Hi there your remote starter is a DSE remote starterAlarme system   the Da 900  is a channel expander  to do the sliding door if you want more info about your system just give me a call after 5 pm  at  (450) 701 8745     my name is Jacques (Jack )
cocolaboy
Thursday, November 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
