2008 subaru legacy remote start
autoneon
Member - Posts: 10
Posted: December 02, 2007 at 7:40 AM / IP Logged
I have a 2008 Subaru Legacy SE
4cyl manual trans
I want to install a remote start in it
what is suggested and does anyone have a wiring diagram as I have been unable to find one
thanx in advance
JWorm
Platinum - Posts: 2,208
Posted: December 05, 2007 at 6:27 AM / IP Logged
The car hasn't changed body styles for a few years. Wiring will be the same as 2005.
https://www.the12volt.com/installbay/forum_posts.asp~TID~84353
autoneon
Member - Posts: 10
Posted: December 22, 2007 at 7:15 PM / IP Logged
I need help with wire locations for the following:
factory alarm arm and disarm, tachometer, and parking brake wire
someone please help ASAP
KarTuneMan
Platinum - Posts: 7,056
Posted: December 22, 2007 at 8:44 PM / IP Logged
What are you installing?
autoneon
Member - Posts: 10
Posted: December 22, 2007 at 9:46 PM / IP Logged
it's an ultra start remote start
tedmond
Gold - Posts: 4,610
Posted: December 22, 2007 at 10:01 PM / IP Logged
as jworm mentioned, read this post. it has wiring diagram location and colour of wire. look then ask for help if needed. As for the alarm you purchased, ultra starts are good units. have one of my moms car and it works pretty good. decent range.
KarTuneMan
Posted: December 22, 2007 at 10:16 PM / IP Logged
Ultra start part #......? I know, I know..... why am I asking, like it matters. It does. I hope you got a unit for manual transmission. (you did ...right?)
JWorm
Posted: December 23, 2007 at 12:07 AM / IP Logged
Those wires are clearly indicated in the first post I referenced. Here, let me copy and paste them for you:
Tachometer      pink to RED / white       ac       ECM, 34 pin plug, pin 23 or cluster
   Notes: The ECM is behind the glove box.
   Can also go to a fuel injector under the hood and use the wire that is NOT blue/black (4 cyl), red (4 cyl turbo), or yellow/blue (6 cyl).
Parking Brake      gray       -       sw or driver kick, harness to rear
Factory Alarm Arm      brown       -       dr kick or BIU, 35 pin plug, pin 3
Factory Alarm Disarm      yellow/red       -       dr kick or BIU, 35 pin plug, pin 12
   Notes: The BIU (Body Integrated Unit) is to the right of the steering column.
autoneon
Member - Posts: 10
Posted: December 23, 2007 at 6:26 AM / IP Logged
The unit is for manual trans
As for wiring, I connected most of the wires except for the ones mentioned above
I'm just looking to find out the exact location of the BIU or what it looks like so I can easily locate it.  Or where to look in the driver kick.
Also, would I be able to connect directly to the clutch wire or would I need to use a relay?
Thanx
autoneon
Member - Posts: 10
Posted: December 24, 2007 at 10:56 AM / IP Logged
figured out all the wiring but the clutch
anyone know would I be able to connect directly to the clutch wire or would I need to use a relay????
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
