2001 galant es, alarm/remote start
shadowinfector
Copper - Posts: 199
Posted: December 10, 2007 at 1:45 PM / IP Logged
2001 Mitsubishi Galant ES
have a 2001 Mitsubishi Galant ES for install of alarm/rs.....anything special i should know or where its easier to catch wires...any help would be appreciated...thanx
shadowinfector
Copper - Posts: 199
Posted: December 12, 2007 at 10:12 AM / IP Logged
any help please...wiring diagram if available...thanx and is there anything out of the ordinary on this vehicle
KarTuneMan
Platinum - Posts: 7,056
Posted: December 12, 2007 at 10:34 AM / IP Logged
Nothing special............
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Red or Blue / YELLOW Ignition switch harness   +
 IGNITION BLACK/ white or WHITE/ black Ignition switch harness   +
 ACCESSORY Blue/black Ignition switch harness   +
 STARTER BLACK / YELLOW Ignition switch harness   +
 KEY SENSE Blue/red Ignition switch harness   -
 TACH SIGNAL See notes    AC
 On the 2.4L the tach is BLACK/ BLUE or WHITE/ GREEN (2 cyl. Signal) at either of the 2 coils on the top of the engine. On the 3.0L engine the tach is WHITE at the test connector on the engine relay box under the hood, set your remote starter for 6 cylinders.
 LOCK Purple In harness from driver's door   -
 UNLOCK GREEN/ red In harness from driver's door   -
 DOORPIN RED / black At ring around ignition switch   -
 HOODPIN Blue/black At fuse/junction block   -
 This wire is found only on models equipped with factory security.
 TRUNK PIN White At fuse/junction block   -
 FACTORY ARM Lt.GREEN/ black At fuse/junction block   -
 FACTORY DISARM Red At fuse/junction block   -
 BRAKESWITCH Green At switch above brake pedal   +
 PARKLIGHTS GREEN / WHITE In connector on fuseblock   +
 HAND BRAKE YELLOW /GREEN At plug on handbrake lever   -
 HORN Lt.green At steering column   -
