99 Camry - is it a fuse?
slarsen
Posted: April 06, 2003 at 4:04 PM / IP Logged
There is a small black box on the lower right drivers side fuse box on my 1999 Camry CE.  It is not included on the fuse box diagram.  It fell out several months ago while I was installing remote door locks.  The car seems to be functioning well without this (except that the automatic door locks don't work with or without this installed).  Is this a fuse that is blown?  or is it something else that I should leave for a Toyota dealer to replace. I included a picture.  Thanks,
Sean
99 Camry - is it a fuse? -- posted image.
x6369x
Copper - Posts: 108
Posted: April 08, 2003 at 9:35 PM / IP Logged
Looks like a circuit breaker. It's possibly bad, and that's why the locks don't work either way. Look for a spare somewhere. If no spares, borrow one from a nother location.
Friends Don't Let Friends Bump Stock.
copcarguy
Copper - Posts: 122
Posted: April 13, 2003 at 7:16 PM / IP Logged
Why not check the continuity across the two posts of the breaker to see if it is really bad. Good continuity will mean problems elsewhere in the vehicle. That would be where I would start.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
slarsen
Posted: April 13, 2003 at 11:23 PM / IP Logged
I have figured out what was wrong with my locks (completely different problem - a circuit board was burned out).  I am still curious as to what this is.  There is no continuity across the two posts and since I got my locks fixed the car seems to function 100% without it.  Is it possible this is just some kind of blank to fill an unused spot in the fuse box?
Sean
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
