Electric switch solinoids
pdltfc
Posted: April 11, 2003 at 10:04 PM / IP Logged
When testing an electric switch solinoid from the ignition switch in the following manner.  A ground to ground terminal a positive to ignition terminal you can hear a click if the sonlniod is operating correctly I 'm told.  When you place your voltmeter on the top post of this solinoid that now leads to the soliniod that kicks the flywheel over what should your voltage be?
copcarguy
Copper - Posts: 122
Posted: April 13, 2003 at 7:11 PM / IP Logged
If your voltage in reads 12.5 volts then the switched side of the selonoid should read exactly the same when engaged. If there is a drop in voltage from one terminal to the other when engaged then the internal contacts or the coil windings are bad. Either way replace it if you do not see identical voltage on the line and load sides of the selenoid.
Hope this helpsElectric switch solinoids -- posted image.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
pdltfc
Posted: April 14, 2003 at 9:34 PM / IP Logged
R. Jackson Thanks for your reply.
copcarguy
Copper - Posts: 122
Posted: April 15, 2003 at 9:19 AM / IP Logged
No problem. Hope I was some help to you! Take care.
R Jackson
Owner/Installer
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
