Olds self leveling rear struts
ddellinger
Posted: May 28, 2003 at 2:08 PM / IP Logged
The rear struts on my Olds 98 are the self leveling kind and they don't work.   I have tested the pump, off the car and it works.  I pull ed the level switch and it is solidstate so no way to check with out diagrams.
Any ideas?
Doug
Seth454
Posted: July 23, 2003 at 10:47 AM / IP Logged
have you tested the struts for blown seals?
ddellinger
Posted: July 24, 2003 at 7:03 PM / IP Logged
The shocks hold air, the pump works if you connect it to 12v.  It seems like the electronics which control the pump, don't work.
Doug
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
