walkthrough to hook up 3 neons
accord_customiz
Member - Posts: 21
Posted: June 09, 2004 at 9:32 PM / IP Logged
thank u anyone who helps me wiht this.
i want a walkthrough on a good way to hook up three neons to.....say my radio or soemthin.
if anyone has enough time to help me out that woud be greatful.
thank you
Ravendarat
Platinum - Posts: 2,806
Posted: June 09, 2004 at 11:52 PM / IP Logged
You want to hook it up so they blink or just so they are on when you turn the car on?
accord_customiz
Member - Posts: 21
Posted: June 09, 2004 at 11:59 PM / IP Logged
want to make it so i can hit a switch and all go on
accord_customiz
Member - Posts: 21
Posted: June 10, 2004 at 12:00 AM / IP Logged
or i turn somehtin on they go on
Ravendarat
Posted: June 11, 2004 at 11:21 PM / IP Logged
Just buy a regular 2 position switch. Hook up all the groounds off the lights to ground, hook up a fused 12 volt line to the one side of the switch and all the positives off the lights to the other side of the switch. Flick switch and watchem glow.
veneficus
Member - Posts: 15
Posted: June 14, 2004 at 11:01 AM / IP Logged
if youve got money to spare, there are a few different companies that make interface controllers for neons/strobes etc. i know streetglow has a neon interface that would probably do what you are looking to do. optx might too. if you do a bit of research, www.slickcar.com, jcwhitney.com, those 2 carry a lot of stuff.  Ive done a few different things with complex switching and cool stuff like that, if you like, email me with what you are trying to get done, I can probably get you through it.
chammond_30@comcast.net
thestreetFX  AIM screen name
Chris
StreetFX
yardmant
Posted: June 28, 2004 at 11:26 PM / IP Logged
I JUST HOOKED UP A 12 VOLT Y CONNECTOR IN A CAR TO RUN NEONS THEY LITE UP BUT NOT ALL THE WAY IT ACT LIKE A BAD GROUND. I HOOKED POWER DIRECT TO THE BATTERY ALONG WITH GROUND TO THE NEG. SIDE. WHAT DID I DO WRONG
yardmant
auex
Platinum - Posts: 5,041
Posted: June 29, 2004 at 1:17 PM / IP Logged
I wonder if he is going to ask how to hook up the neons 1 more time, in addition to the other 3 times. Here, here, and here. Until you understand how 12V works, maybe you should pay someone to install these for you.
Please don't feed the trolls.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
accord_customiz
Member - Posts: 21
Posted: July 07, 2004 at 12:50 AM / IP Logged
WOW ok heres how it goes. take 1 wire and go to the switch from pos battery.
take other wire from other side of switch to neon.
take black wire FROM neon and loosen a bolt on the body and wrap wire around it and tightin.
thats wat i did and they light like u wouldnt belive
ALL thanks to street FX (chris)
