possible starter going bad?
mustangfoo
Silver - Posts: 371
Posted: May 11, 2006 at 4:54 PM / IP Logged
Ok here is my issue.  I have a 94 Suzuki Sidekick and the ignition went bad and did not have the money to replace it so instead I put a push button start which works fine.  The problem is that sometimes when I go to start my car (even after it has just been shut off) it has trouble starting back up.  For instance last night I stopped to pump gas no problems, go to start her back up and the SOB wouldnt turnover you could just hear it cranking.  Now could this possibly be the battery or maybe the switch?  Never had problems with the switch before but it could most likely be possible.  It just doesnt make sense that the car will not start after being shut off for less than 5 minutes.  Any ideas or suggestions on how to test anything besides pulling the damn starter off and taking it to autozone would be greatly appreciated, but if push comes to shove I will have my starter tested if no one can help me try to figure out my problem.
THANKS GUYS! possible starter going bad? -- posted image.
mustangfoo
Silver - Posts: 371
Posted: May 11, 2006 at 9:02 PM / IP Logged
ok check it outI just went to COSTCO which is where I had bought the battery I had in my car before and exchanged it for a better one went out re-installed it and went to start my car.  I cranked it about 5 times before the darn thing would start.  I am now convinced that this is either a problem with the switch OR possibly the starter is going to give out soon.  Any suggestions gentlemen?
Aruman
Silver - Posts: 363
Posted: May 12, 2006 at 7:32 AM / IP Logged
check this thread hope it help you out.
Shaking The Neighborhood
mustangfoo
Silver - Posts: 371
Posted: May 13, 2006 at 4:14 AM / IP Logged
thanks, I will take a look at that!
stevdart
Platinum - Posts: 5,816
Posted: May 14, 2006 at 9:45 AM / IP Logged
There are sensors that go bad that provide those symptoms.  It's tough troubleshooting sensors.  One such sensor is installed in the exhaust manifold and if it is sticking or worn out it won't let the car turn over.  Buy yourself a Haynes manual and go through the troubleshooting procedure for this problem.
