bmw power folding mirrors
lexizpumpin1
Posted: March 04, 2008 at 10:29 PM / IP Logged
Ok this has been discusted a few times the mirrors have a blue wire and a white wire if you give blue + and white - they open if you reverse polarity they close they dont have a timer to stop them im loooking for a simple device that can use trigger to time open them then again with a different trigger close them also with time the trigger is +
let me know can pack tr-7 work?
Platinum - Posts: 12,488
Posted: March 05, 2008 at 9:19 AM / IP Logged
You can go here for the thread that explains how to do it.
rob_fed
Member - Posts: 15
Posted: March 21, 2008 at 4:37 PM / IP Logged
Your idea to create a timed event or keeping the relay powered for a set amount of time would work. You can use a the delay circuit from the relay diagrams from this site. But I think the duration to open and close the mirrors is longer than the amount of energy that a capacitor can store, unless you have a big capacitor. You might have to use a 555 timer circuit to get the amount of on/off time you needed. Another thought, do power open/close mirrors have limit switches? If so, then you do not need a timed event. A power window circuit that provides one touch up and one touch down may be your answer.
