relay input
3onthetree
Member - Posts: 14
Posted: September 24, 2008 at 8:32 PM / IP Logged
I have a 791xv alarm and am trying to run solenoids for air ride. When I put a tester on the aux output (I tried the channel 2, 5, and 6), I got about 600 milliamps. When I plug it into the relay, I cannot get it to switch, and it drops to about 100 milliamps. Are there differet relays for different voltage inputs?
3onthetree
Moderator - Posts: 12,488
Posted: September 24, 2008 at 9:21 PM / IP Logged
You need about 250-200 mA to trigger the relays. Make sure that the ground is good on the 791.
3onthetree
Member - Posts: 14
Posted: September 25, 2008 at 7:38 AM / IP Logged
Thanks for the quick reply. I have a good ground on the 791. I was finally able to get the relay to click this morning with a different wiring diagram for the relay. I have seen a few different wiring diagrams for relays. With the one that I used this morning, I was able to get the relay to click, it is just not putting out the 12 volts to the solenoid I am trying to control. What would the wiring be for a relay with 85,86,87, and 30?
3onthetree
megaman
Copper - Posts: 385
Posted: September 25, 2008 at 9:12 AM / IP Logged
to control the relay it's simple:  85-channel ouput.  86- +12v.
If you need +12 to your solenoid then 87 - +12v, 30 - solenoid
If you need ground to your solenoid then 87 - ground, 30 - solenoid.
make sure you fuse your 87 +12v input.
3onthetree
Member - Posts: 14
Posted: September 25, 2008 at 10:32 AM / IP Logged
Hey Jeff,
Now I get the 600ma when the relay is not hooked up, when I connect it to the relay it only gets about 100ma. Does that make any sense?
3onthetree
Posted: September 25, 2008 at 10:44 AM / IP Logged
Do you have a diode between pins 85 and 86 ?
3onthetree
Member - Posts: 14
Posted: September 25, 2008 at 10:45 AM / IP Logged
You will have to excuse my ignorance, but I thought that was in the relay?
3onthetree
3onthetree
Member - Posts: 14
Posted: September 27, 2008 at 1:00 PM / IP Logged
Hey Jeff,
Thanks very much for all your help. I got it now and it is working like a top. The site is great, thanks for all your help.
3onthetree
Wednesday, October 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
