push button start
deziac
Posted: November 21, 2008 at 11:57 AM / IP Logged
Newbie trying to learn here, so please bare w/ me. I'm trying to install a push start button w/ ignition switch. I'm having troubles understanding and I need your help.(thanks) So I have the switch and push button, but the amperage is not enough so I will have to use a relay. I'm not sure how to apply this relay diagram:
http://www.instructables.com/id/SB5TWAJFBGW8EXP/
to wiring to this:
http://forums.bimmerforums.com/forum/showthread.php?t=617587&highlight=switch+panel
Please forgive my idocity, but if you guys can tell me how and what wires to hook up It would be much appreciated.(a visual diagram would be extremely helpful)
deziac
Posted: November 22, 2008 at 6:49 PM / IP Logged
can anyone here help me w/ this?
Platinum - Posts: 13,725
Posted: November 23, 2008 at 6:43 AM / IP Logged
Are you planning to remove the Key Cylinder and steering lock? If not, why not just add a push to start button?
What is the amperage rating on the push button switch?
deziac
Posted: November 25, 2008 at 3:22 PM / IP Logged
I am planning on keeping the key cylinder and lock, I just don't know how to add the switches to a relay, as the amperage is only 6a
Saturday, January 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
