latching relay system
trex_202
Posted: September 23, 2009 at 5:19 PM / IP Logged
Hi.
I had the need for a switching relay, and ended up with the designed shown in the figure.
However, I have a problem, the relays switches on an off 50 times a second :-(
latching relay system -- posted image.
Is there any easy way of creating a debouncer for the push button?
The bi-stable relay needs a polarity change, therefore the setup.
Regards,Tommy.
Platinum - Posts: 13,726
Posted: September 23, 2009 at 6:00 PM / IP Logged
Would a latching relay with a pushbutton to latch and the same pushbutton to unlatch help you at all?
trex_202
Posted: September 24, 2009 at 2:06 AM / IP Logged
Yes, this is going to be used for switching on/of some lights, and the factory switches are push-type. So nothing I can do about it.
However, the solution I am after is some way of sending a pulse. I tried with a 555 timer IC, but the output of that is not high enough current to work the coil of the relay.
Any suggestions?
Tommy.
Posted: September 24, 2009 at 5:45 AM / IP Logged
KPierson
Platinum - Posts: 3,527
Posted: September 24, 2009 at 11:30 AM / IP Logged
Take the output of the 555 timer and run it through a transistor to the relay
Kevin Pierson
katman
Member - Posts: 15
Posted: September 24, 2009 at 5:13 PM / IP Logged
Looking at the schematics I found no values for the diodes in the circuits operating the coil of the various relays.  Any clues to a post showing the value needed to carry such a load?
"All paid jobs absorb and degrade the mind."
Aristotle
Posted: September 24, 2009 at 6:05 PM / IP Logged
1n400X   X = any number from 1 to 7
hotwaterwizard
Silver - Posts: 1,350
Posted: October 10, 2009 at 2:13 PM / IP Logged
A Relay switching that fast will make a soundnd like a buzzer. Better to use a couple of Transistors.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: October 10, 2009 at 2:27 PM / IP Logged
You could just use all transistors to do the job.
Stockton California
ckeeler
Gold - Posts: 1,461
Posted: October 10, 2009 at 4:22 PM / IP Logged
your 555 setup will work by just adding a transistor to activate the relay like KP suggested. if you already have the 555 setup built, it's a lot less work to just add a transistor than to start all over from scratch.
