solenoid for electric fan
mkswmp
Posted: December 20, 2009 at 5:24 AM / IP Logged
hi newbie here and i have a 2007 tacoma that i want to install a mark VIII electric fan on using a constant duty solenoid instead of relays.
Posted: December 20, 2009 at 6:50 AM / IP Logged
What's the difference?
Platinum - Posts: 13,726
Posted: December 20, 2009 at 7:52 AM / IP Logged
How many small terminals are on the solenoid?   What is your question?
oldspark
Gold - Posts: 4,913
Posted: December 20, 2009 at 4:35 PM / IP Logged
A solenoid is the "actuating" or coil part of a relay.
A solenoid can also be a coil that moved something - eg, a core that gets pushed through - as used in door chimes, klaxons, locks etc.
Solenoid is often used as a generic term like relay and maybe contactor.
If by constant duty you mean full-time rated, most automotive relays will do the job.
Of you want a latching relay or contactor, I would question why, and point out that you would need suitable control circuitry.
