relay negative trigger from tacho.
rickyz_cube
Member - Posts: 6
Posted: August 07, 2011 at 1:30 AM / IP Logged
hi all, i am new to this site,
i am trying to make my tacho turn a relay on when the shift light becomes active.
my tacho has a 12v positive and a switchable earth that triggers the shift light to come on.
when i hook this wire to the relay it has 12v earth, then when i connect the 12v+ to the other pins, the earth becomes 2.3v, why would this be?
Cube<3.com
Posted: August 07, 2011 at 1:56 AM / IP Logged
and it still doesn't work, you might not be sinking enough current. PM Oldspark, or Kevin Pearson.
rickyz_cube
Member - Posts: 6
Posted: August 07, 2011 at 2:00 AM / IP Logged
so what goes to which pins? the light wires are 12v constant and 3v+ until shiftlight active then it becomes ground.
so
86 = 12v+
85 = switchable earth
30 = ???
Cube<3.com
Posted: August 07, 2011 at 2:17 AM / IP Logged
I suppose since you can't read the diagram try the following:-
suspected tacho switching ground to 85.
Ignition live to 86 and 87.
Lamp output from 30.
Don't use 87a.
Don't forget the 1N4004 diode across 85 and 86 with the band towards 86 or you will destroy your tachometer.
Alternatively, if you use a 12volt LED, forget the relay and just run the positive side to 12v+ ignition and the neg side to the switching output.
Posted: August 07, 2011 at 2:18 AM / IP Logged
Correction, 3 volt LED.
rickyz_cube
Member - Posts: 6
Posted: August 07, 2011 at 2:20 AM / IP Logged
im not using a shift light, just the output from tacho, the wires i have are:
12v+
12v+ switched
switching earth (shift light trigger)
Cube<3.com
rickyz_cube
Member - Posts: 6
Posted: August 07, 2011 at 2:22 AM / IP Logged
my relay works when i put the earth wire onto a actual earth, but it does not work from the output from the tacho, the voltage seems to drop when power hooked into relay
Cube<3.com
Posted: August 07, 2011 at 2:25 AM / IP Logged
Use the shift light to turn on the relay!
rickyz_cube
Member - Posts: 6
Posted: August 07, 2011 at 2:28 AM / IP Logged
thats what i am trying to do, the two wires going to the shift light from the tacho are:
red = 12v+ constant
black = earth only when above desired rpm
the problem i am having is the earth is not triggering the relay,
it works the multimeter fine when not hooked into the relay (says 12v),
but when i put 12v into the relay, the multimeter says 2.3v,
what can cause this?.
Cube<3.com
Posted: August 07, 2011 at 2:48 AM / IP Logged
It's not sinking enough current to trigger the relay or you wired the relay wrong.
Ground (earth) to 85, 12V+ to 86 and 87, output (12Volt+)from 30.
Or you need a relay with 3 volt coils.
