latching master relay wiring
seattle_ice
Member - Posts: 37
Posted: September 30, 2011 at 8:07 PM / IP Logged
I would appreciate some verification by more experienced auto wiring people as to the suitability of my wiring diagram.
What I have is a master latching solenoid (relay) for the whole car. I want to wire it so that a DPDT momentary(center-off) switch will switch the state, but will do nothing when you try to turn it on if it is already on, or off if it is already off.
latching master relay wiring -- posted image.
oldspark
Gold - Posts: 4,913
Posted: October 01, 2011 at 8:27 PM / IP Logged
Not that I'd recommend a relay for the whole car (unless with redundancy - ii, 2 relays), but why not use an ordinary relay as per:
seattle_ice
Member - Posts: 37
Posted: October 02, 2011 at 2:26 AM / IP Logged
Because the latching relay uses no current to maintain its state, so would not drain the battery over time while in storage, and is designed to handle 150+ amp loads.
oldspark
Gold - Posts: 4,913
Posted: October 02, 2011 at 7:38 AM / IP Logged
So why would you want the relay "ON" (ie, car connected) if in storage?
Granted, whilst on, an ordinary relay will take say 50mA - 200mA depending, but that is insignificant with the engine running else for short periods (maybe overnight etc).
Otherwise for a dual-coil latching relay, why not one push button for on & one for off?
PS - IMO there is no need to quote previous replies in full....
Platinum - Posts: 13,726
Posted: October 02, 2011 at 8:00 AM / IP Logged
Does the latching solenoid require reversing polarity to change states?
Ween
Platinum - Posts: 1,368
Posted: October 02, 2011 at 1:23 PM / IP Logged
hi,
guessing the solenoid in question does require reversing polarity
to change states. solenoid of that type is often used in motor homes/coaches as a master disconnect.
Posted: October 02, 2011 at 1:36 PM / IP Logged
I did not fully inspect the diagram, but I did notice that T2 will never see positive voltage.  Both legs of that pole of the switch are at ground.
seattle_ice
Member - Posts: 37
Posted: October 02, 2011 at 2:51 PM / IP Logged
It would be off for storage. I just don't want it draining power when it is on, but the car is not running.
A DPDT switch is essentially the same as two switches, so that is just semantics.
No, it does not. It simply flips every time it sees voltage, so it does not matter which of the T1/T2 legs gets positive and which gets negative.
seattle_ice
Member - Posts: 37
Posted: October 02, 2011 at 4:27 PM / IP Logged
OK, after looking at that first diagram for a while it will not work. So I am starting from scratch to make this easier to understand.
The following diagram is what I need except for one thing - If the power is on, and you push the switch to "ON", it will turn the power off. I want it do nothing.
Posted: October 02, 2011 at 4:42 PM / IP Logged
The above diagram will change state everytime you push switch to the left.  If it is on, and you push the switch either direction, it will turn off.  If it is off and you push switch to right, it will do nothing.
Page of 3
