pulsed to steady output circuit
ultm8z
Member - Posts: 7
Posted: June 30, 2013 at 11:10 AM / IP Logged
On this circuit diagram, what diodes are being used?
https://www.the12volt.com/relays/relaydiagram22.html
Thanks.
Platinum - Posts: 13,726
Posted: June 30, 2013 at 3:40 PM / IP Logged
1n400x x=any number from 1 to 7
ultm8z
Member - Posts: 7
Posted: July 01, 2013 at 8:14 AM / IP Logged
Thanks!
Also, what size resistor (in terms of power) would do the trick here?  Is a 1 watt resistor sufficient?
oldspark
Gold - Posts: 4,913
Posted: July 01, 2013 at 10:01 AM / IP Logged
IMO that resistor can be omitted.
But otherwise, any resistor wattage - eg: 1/8W, 1/4W, 1/2W etc.
ultm8z
Member - Posts: 7
Posted: October 26, 2013 at 11:36 AM / IP Logged
I wired up this circuit finally...
Problem is it's clicking the relay on and off at the same rate as the turn signal flasher.
The schematic is showing polarized capacitors. Do they have to be polarized?
ultm8z
Member - Posts: 7
Posted: October 26, 2013 at 11:38 AM / IP Logged
Also, am I reading this schematic correctly when it's telling me I need 10,000 mfd (microfarad) capacitors in this circuit?
ultm8z
Member - Posts: 7
Posted: October 26, 2013 at 4:07 PM / IP Logged
Disregard my previous posts...
I searched and found another thread where it was confirmed that the schematic is calling out a 10,000 uF cap.
Went to the local Fry's, picked up a couple of them and boom, circuit works like a charm!!
