timer relay normally open
zj4041
Posted: July 27, 2014 at 11:50 PM / IP Logged
Hi all, just signed up for a project I am working on.
seems like alot of experienced people here. Im a mechanical engineer so forgive me as i try my best to put my electricians hat on.
Looking for a normally open timer relay that will short a 18v, 20 amp circuit 2-6 seconds after receiving a 12v signal.
I came across the popular 528t relay. will this work? and if not what other options do I have?
Fyi this is for a slow starting of a dc motor that is to start with high resistor at first to prevent over torque and slip, then once it gets moving the timer relay is to short the resistor out so the motor can go full speed after the slow start.
Thank you
Robert
Posted: July 28, 2014 at 5:31 PM / IP Logged
528t will work fine in this application.
Posted: July 28, 2014 at 5:32 PM / IP Logged
I might be wrong but there are also OEM relays for automotive AC with a 3 second delay built in.
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
