Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
When the power comes on, it will turn the latch on.
When the power goes off, the trigger relays (far left, and 3rd from left relay) will change state.
Power on again, latch turns off.
Power off, trigger (right 2 relays, purple) changes state.
Rinse and repeat.
Connect the output of the array (blue) to as many double-throw relay coils as you need to do the switching you require. The N.O. contacts in these relays will be the array ON, and the N.C contacts will be the array OFF.
I offer one caution. You must connect the "Constant 12V supply (red) to an IGN or ACCY source because if the array is ON when you shut the IGN off, the array will stay energized until the battery goes dead. With 3 coils energized, the draw is significant. When you do this, the initial power-up of the radio will always result in the array turning ON. so make the N.O. contacts of your switcher relays the priority.
This should get you going.
