Actuator diagram
draperwilliam08
Member - Posts: 7
Posted: August 18, 2015 at 11:28 AM / IP Logged Link to Post Post Reply Quote draperwilliam08
I need help with a circuit to run a acuator on a 12 volt timer. when the timer engerizies the acuator extends til it's built in limit switches is hit then when the timer cuts off the acuator rises til it hits other limit switch built in the actuator
hotwaterwizard
Silver - Posts: 1,350
Posted: August 19, 2015 at 10:10 PM / IP Logged Link to Post Post Reply Quote hotwaterwizard
not enough info on timer or actuator.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
draperwilliam08
Member - Posts: 7
Posted: August 19, 2015 at 11:09 PM / IP Logged Link to Post Post Reply Quote draperwilliam08
It's a digital timer switch with on off. And the actuator is reverse polarity to switch directions
hotwaterwizard
Posted: August 19, 2015 at 11:11 PM / IP Logged Link to Post Post Reply Quote hotwaterwizard
Electric Diagrams Part Numbers anything?
Stockton California
Posted: August 20, 2015 at 12:05 AM / IP Logged Link to Post Post Reply Quote howie ll
I didn't answer this for the same reason as HWW.
The answer is a timer relay plus 1 regular relay.
But how long to run?
Power consumption?
See where this is going?
You could do this manually with a Spal power window switch but again, power rating, what I just said = standard window closer with auto close.
draperwilliam08
Member - Posts: 7
Posted: August 20, 2015 at 12:16 AM / IP Logged Link to Post Post Reply Quote draperwilliam08
Timer website.    http://m./itm/Digital-LCD-Programmable-Timer-DC-12V-16A-Time-Relay-Switch-/300629327093?nav=SEARCH
Actuator website    http://m./itm/Linear-Actuator-2-Stroke-225-Pound-Max-Lift-12-V-Volt-DC-Heavy-Duty-2-inch-New-/320948568171?nav=SEARCH   Needs to run til it fully extended the cut off for 4 hours and the run til it fully retracted the cut off for 4 hours hope this helps
draperwilliam08
Member - Posts: 7
Posted: August 20, 2015 at 12:19 AM / IP Logged Link to Post Post Reply Quote draperwilliam08
It's all 12 volts
