If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Saturday, May 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
On the back, the two switches on the left set positive or negative trigger and high or low delay range. The two potentiometers at the top set On and Off delay.
