If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Wednesday, April 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I need pin 87 to output a slightly smaller gauge wire so that I can jump the wires like this so I can buss terminals together.
This can not be achieved with the 12ga wire, the 14-12ga Metri-Pack 280 terminals I cant get two 12ga wires crimped propery into one terminal. Just too much wire.
I have (4) wire leads from the igntion switch to the fuse panel where they are crimped to bussed pack-con III terminals like this.
(1)Red - Hot all times
(Pwr/acc breaker 30amp, ecm fuse, stop-haz)
(1)Orange - Hot in run
(AC, powerWindow breaker 30amp, C/H fuse)
(1)Brown - Hot in Acc or Run
(Raido, Wiper)
(1)Pink - Hot in run, bulb test or start
(Gauges, Ign/Ecm, Turn B/U)
