Sequential Taillights
novicewire
Posted: April 30, 2016 at 6:55 PM / IP Logged Link to Post Post Reply Quote novicewire
Greetings
I humbly ask for advice on relay wiring. I would like to have sequential tail lights. I've found a diagram online that uses 3 lights and 2 relays. It was written by HotWater Wizard. How would I add another light? Also, is a diode required for the relays to last longer? Many thanks!
Novice
Novice Wiring Guy
namorbrowneyes
Posted: November 28, 2016 at 9:49 AM / IP Logged Link to Post Post Reply Quote namorbrowneyes
Hello, it sounds like you want to use 3 outputs ie. 3 bulbs (or any # really..)to blink in sequence and create a pulse effect. I have only seen 3 good options for this.
http://store.ijdmtoy.com/4-Step-Sequential-Flash-Module-Box-p/aa1168.htm
http://sweeplite.com/
http://www.webelectricproducts.com/
I wish I had enough bulbs to do this to the car I have now... I miss this effect.
Friday, October 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
