Relay or Diode?
dxtreme_85
Member - Posts: 8
Posted: July 31, 2003 at 2:15 PM / IP Logged
What I've done:
Basically, I am installing a switch on the voltmeter in my car so that when I flip the switch it sends power to the gauge.  This is so that I can check the volt's on the car, without having to put the key in the ignition and turn the car to on.  Currently my main wire running directly to the gauge.  This wire is only hot when the car is in the 'on' position.  I tapped into this wire with a constant wire that I brought off of the switch I was using, and placed a diode on the main wire (wire that is only hot when car is on).  This should stop the rest of the vehicle from coming to life when I flip the switch.
My Problem:
When I flip the switch with the car off, the gauge reads where it should and used to read all of the time.  However, when the car is running, it reads closer to 12 volts, when it used to read 13.8 volts.  Should I do away with the diode altogether and use a relay to activate the gauge instead.  Relay wired as follows:
  • pin 85-Ignition (hot only when car is 'on')
  • pin 86-Ground
  • pin 87-12V+
  • pin 87a-wire leading into normally open switch, then into gauge
  • pin 30-wire leading into gauge
What I have assumed my problem is, is that I am getting a draw from the diode, and I was told that a relay would only show a voltage drop of less than 200 milliamps.
Is all of this worth my trouble???
-Terry
xetmes
Silver - Posts: 586
Posted: July 31, 2003 at 3:29 PM / IP Logged
a diode will drop .7 volts, so you might wanna take that into consideration, That relay configuration should work as far as i know, looks good Relay or Diode? -- posted image.
MrWildBob
Posted: August 02, 2003 at 10:48 PM / IP Logged
This is just my Opinion, but I would end up getting a digital palen volt meter display and hook it up to your battery directly.  That way you can see the voltage all the time.  No need for switches and stuff.  Also, it will draw very little current.  I think RadioShack or some surplus stores in your area would have that in stock.  Being digital will make it a lot more accurate.  Plus, I think it looks cooler.
Hope this helps
boB
dxtreme_85
Member - Posts: 8
Posted: August 04, 2003 at 4:12 PM / IP Logged
Ok guys, I got it right.  I installed the spdt relay today, I was wrong -above- for what terminals to use, but I straightened things out.  I no longer get a voltage drop and the gauge reads true.  Mrwildbob, thanks for the input, but I already have an autometer voltmeter in an A-pillar gauge pod, and it does the job just fine, just had to do away with the voltage drop.  Thanks xetmes for the help
xetmes
Silver - Posts: 586
Posted: August 04, 2003 at 5:04 PM / IP Logged
you mean the part where it says "pin 87a-wire leading into normally open switch, then into gauge", should be
pin 87a-wire leading into normally open switch, then to 12V.
damn you could just have put a momentary switch between 87 and 87a, but thats probably what you did.
Man i missed that completely, sorry Relay or Diode? -- posted image.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
