ON/OFF Relay Diagram
install_tech
Member - Posts: 37
Posted: April 03, 2002 at 1:05 PM / IP Logged
I am looking for a relay diagram that will allow me to use a (-) auxillary channel output from an alarm system to trigger a relay to turn on or off a 12volt source. ie. neon lights /radio/ ect. The end result, first push of the button on the remote will turn on device. The next push of the button will turn it off. Thanks in advance for any input!
install_tech
the12volt
Administrator - Posts: 3,957
Posted: April 03, 2002 at 1:57 PM / IP Logged
Hi install_tech, all you need is a latching relay to control it as you described.  You can get them at most Radio Shacks or your local electronics shop.
the12volt
hot_shot_guy123
Copper - Posts: 114
Posted: April 13, 2002 at 6:30 PM / IP Logged
What's up install_tech, I have a diagram but I don't know how to get it to show up on here so I'll type out the connections.  This one that I will explain is for hooking up your radio to the auxillary.
PIN 85 = aux. output from alarm
PIN 86 & 87 = to radio's memory wire
PIN 30 = to radio's ignition wire
PIN 87a = to radio's ignition wire
NOTE:the ignition wire to the radio is cut between the connection of 87a and 30, the wire is not solid.  Any other questions post em'
go2pac
Copper - Posts: 179
Posted: May 05, 2002 at 4:33 AM / IP Logged
this will do what you want.
 ON/OFF Relay Diagram -- posted image.
http://www.go2pac.com/misc/miscdiagrams/latchrelay.pdf
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
bensalvage
Member - Posts: 9
Posted: May 07, 2002 at 9:29 PM / IP Logged
I would like to make a circuit that uses a pushbutton to act as a spdt switch. I want to make it where its normaly off, i push the button once and it flips to one way, i push it again and it flips the other way, and i push it again and it turns off. I have about 20  spdt 12 volt relays so the circuit can be as big as it needs to be.  Any help would be great!
Ben
install_tech
Member - Posts: 37
Posted: May 09, 2002 at 8:36 AM / IP Logged
Thanks for all of your input !!
go2pac
Copper - Posts: 179
Posted: May 15, 2002 at 4:33 PM / IP Logged
bensalvage
do you only want to use spdt relays? or do you care to use a module that will do that? what are you trying to accomplish with this setup?
Karl
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
