Relay simulator?
profcarlos
Posted: July 31, 2002 at 4:21 PM / IP Logged
Hi. I'm new here, and I've been learning a lot.
I just bought  a book called "Custom Auto Electronics and Auto Electrical",  by Frank 'Choco' Mundy, in order to learn how to wire my car from scratch. I have a Brazilian KarmannGhia TC 1976, which I want to completely re-wire, using relays for the lights, adding a few mods here and there, etc.
I have been looking for  software which could help me devising the new electrical system; I' ve found plenty of hi-end electronics simulators and CAD drawing software, but I couldn't find a simple thing that would be quite perfect for what I want: a software that allowed me to design an automotive electrical system, simulating its functions. That is, something in which I could, for instance, *see*  the results of the ingenious uses of relays you guys are so good at. It should have ready-made relay, diodes, lamps, etc., and the user would just wire things up and see how they work.
To make things worse, instead of explaining some "details" (like how to concoct a new turn signals system, or how to adapt a modern multi-position windshield wiper system, etc.), the book author tries to convince the reader to buy a ready-made wiring harness, which I cannot do here in Brazil. The import taxes would be so high that it would be easier to buy an used car and reuse its wiring (I am not kidding).
Do you people know any software that could help me?
Thanks in advance,
Carlos from Brazil
scottbrownlie
Member - Posts: 10
Posted: August 01, 2002 at 6:38 PM / IP Logged
Hi Carlos
The following link is for a circuit making program. It should meet your needs. It can simulate most electronic components operating in a circuit.
It's very easy to use once you get the hang of it.
http://www.microcode.com/downloads/student.htm
cdaw
Member - Posts: 22
Posted: August 01, 2002 at 10:21 PM / IP Logged
Thats a cool program, I just cant figure out how to "Push" my  switches
jt
scottbrownlie
Member - Posts: 10
Posted: August 04, 2002 at 8:53 PM / IP Logged
When the circuit is running you should be able to click your mouse on the switch to make it operate. You can assign multiple contacts, which can be all over the place,  to operate off the one switch. Relays contacts can also be all over the place but working off a particular coil.
Scott
