Relay wiring help - negative switched
Fishin2Deep4U
Posted: January 08, 2004 at 2:00 AM / IP Logged
I hope this is in the right place.
I just recently completed the Sport headlight conversion. I am having some difficulty with getting the filaments to follow my commands.
All lights work as they should on low beam. Grab the lever, hit high, no problem. Hit it again to go back to low, no go. If you turn off the lights, it'll switch back to lows.
I followed the schematics I got from members of the TDR. Thanks guys! And all my connections appear to be correct. I am running two harnesses, one for each side of the truck, and everything has it's own relay and fuse.
I seem to remember reading somewhere that others had these same issues and it could be resolved with diodes. Now I don't know anything about diodes, so I need to know what to get and where to put it (on the truck would be helpful).
If anyone could point me in the right direction, I would be eternally grateful!
Dave
Nuthin to tell. In search of knowledge.
Teken
Gold - Posts: 1,492
Posted: January 08, 2004 at 10:25 PM / IP Logged
A schematic of what you did, would help alot.
Regards
EVIL Teken . . .
Fishin2Deep4U
Posted: January 09, 2004 at 1:52 AM / IP Logged
Relay wiring help - negative switched -- posted image.
Fishin2Deep4U
Posted: January 09, 2004 at 1:53 AM / IP Logged
hope that works
xetmes
Silver - Posts: 586
Posted: January 09, 2004 at 7:39 AM / IP Logged
nah it didnt, you linked to your HD, use the upload feature to upload the picture and it should work Relay wiring help - negative switched -- posted image.
Fishin2Deep4U
Posted: January 09, 2004 at 8:53 PM / IP Logged
Lets try this
Teken
Gold - Posts: 1,492
Posted: January 09, 2004 at 11:26 PM / IP Logged
Fishin2Deep4U wrote:
Lets try this
Nope . . . Try again
fredisfound
Copper - Posts: 60
Posted: January 16, 2004 at 5:26 AM / IP Logged
Hi , here is a basic relay layout for this situation, 30 is 12volt+, 86 is 12volt+, 85 is negative trigger, 87 is spotlight output.Hpoe this helps,Tom Allen,,,lost in Queensland Australia.
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
