relay for air horn
modmastermitch
Member - Posts: 6
Posted: May 06, 2004 at 12:45 AM / IP Logged
ok, well iv bought musical air horns and im readdy to fit em. the only thing is, the instructions are rubbish! i have a relay with 4 pins, now ive never used a relay before, ive tried to learn but reading is not as good a tool as using it and applying my knowledge,
so.... i need to know what size cables to wire from the relay to the compresser, and also where the other pins all go to!
help would be appreciated!
*mitch*
underESTimated
Posted: May 23, 2004 at 12:45 PM / IP Logged
*mitch*
I used 16-18gauge wires.
I initially wired it up, without the relay.  But blew a fuse for my brake lights.
No more of that. relay for air horn -- posted image.
I'm just lost for the relay hook up itself.
I have a 5 connector relay using a 30amp.
Posts are like this:
85
86
87
87a
30
Now, how would I wire this up so I dont blow anymore fuses.
Thanx in advance, and this is really the best informative site I've found. :)
modmastermitch
Member - Posts: 6
Posted: May 23, 2004 at 3:31 PM / IP Logged
iv solved my problem,
pin 30 - use 30 amp wire with an inline fuse and hook up to + battery
pin 87 - use 30 amp wire and hook up to + on compresser
connect - on compressor to earth
pin 86 - connect this to a good earth point
pin 85 will go to a switch or the + wire of your original horn, id use a separate switch for this for legal/safety reasons.
and thats it, i didnt have a clue what to do until i9 tried it, iv now wired sevaral  relays up to different things!
*mitc
underESTimated
Posted: May 23, 2004 at 3:55 PM / IP Logged
Thanx Mitch for both reply's and PM  ;)
