off delay relay
ulyses
Member - Posts: 16
Posted: July 23, 2004 at 9:18 PM / IP Logged
hello 12volt gurus: i need help in building an off delay relay that is powered by the +12 parking light.the relay must be able to sustain the energized state through the "off" period of the turn signal flasher routine.
jc18750
Copper - Posts: 113
Posted: July 24, 2004 at 5:53 AM / IP Logged
If you have cornering lights and want them to come on only when your turn signal is on and you do not have a steady output, use the following for each side. This will give you a steady output while the turn signal is on. Increasing the size of the capacitor will give you a longer output if needed.
off delay relay -- posted image.
jc18750
Copper - Posts: 113
Posted: July 24, 2004 at 5:55 AM / IP Logged
my bad on the prebious pic
jc18750
Copper - Posts: 113
Posted: July 24, 2004 at 5:58 AM / IP Logged
sorry, im new to the pictures
