need amp & relay help
LSLFyrFytr
Posted: July 25, 2004 at 10:51 AM / IP Logged
not sure if this is the right forum, but I'm using a relay so here it goes....
I originally had several accessories wired as shown in the diagram.  My problem is that apparently the siren amplifier bleeds off voltage after the relay is switched off, so the strobe light and headlight flasher continue to be powered for a short duration, even after the switch is off.
Is there a way to prevent this from happening?
Thanks!
need amp & relay help -- posted image.
LSLFyrFytr
Posted: July 25, 2004 at 10:54 AM / IP Logged
I should mention that there is no ON-OFF switch on the siren ampliefier itself - the power is controlled by the relay.
Installerny99
Member - Posts: 30
Posted: August 12, 2004 at 8:39 PM / IP Logged
Diode isolate the siren amplifier form the other acc's, this will stop the power from back feeding into them.
InstallerNY99
