Adding door lock switch, relay question
cavyinthegarage
Copper - Posts: 52
Posted: October 27, 2004 at 9:44 PM / IP Logged
hello, I just purchased the spal door lock switch, I want the switch to only work when the ignition is on. So can I use a relay to change the polarity <ign wire +>
to - trigger on the switch side without harming the alarm brain or actuators. So If I can change the polarity I see how to do that on the left. thanks
auex
Platinum - Posts: 5,041
Posted: October 28, 2004 at 11:32 AM / IP Logged
Shouldn't be hard. Wire the switch to pass ign +12V. Then 2 relays for 5 wire locks. But wire 85 as ground and 86 as switch.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
